Our son is in the process of removing the transmission, what is the name of the link rod which that slips into trans that you attach the linkage to for shifting. There is a pin that looks tobe about 6 mm in diameter, also it seems to be missing the clip to secure the pin, what are they called and is there part numbers and a source or I can research with part name/number. Thanks very much.
