99 Honda Accord EX v6 fuel pump issue
Old Oct 9, 2020 | 04:02 PM
Nikita41987's Avatar
Default 99 Honda Accord EX v6 fuel pump issue
Still having the same current issues even after I re-soldered my main relay for the fuel pump would it have anything to do with my ground wire for my subs and my amp being ground on the same piece of metal as the fuel pump is ground out to
Old Oct 9, 2020 | 04:05 PM
2001GSRSC's Avatar
5 Year Member
Default Re: 99 Honda Accord EX v6 fuel pump issue
No the ground should not interfere.
Old Oct 10, 2020 | 07:37 AM
99stockcivic's Avatar
It shouldn't, but for the purpose of testing, I would remove those from the situation until you get everything working. No point in having extra items right now. Reattach when done.
Old Oct 11, 2020 | 10:39 PM
MAD_MIKE's Avatar
MM Gruppe B
Verify voltage to the pump itself.
Verify voltage out of the Main Relay.
Verify voltage at the ignition switch, these wear out and can cause intermittent starting issues from lack of power to the Main Relay.
