2011 Honda Pilot p0302
Hey all. Got a 2011 Honda Pilot with a p0302 misfire code.. replaced the cylinder #2 coil pack and plug.. code popped back up along with the vsa lights. Any advise or help would be appreciated. Thank you.
If the misfire is caused by the VCM and since you're probably no longer covered under the extended warranty; you may want to try installing an aftermarket plug and play, VCM Muzzler 2 to disable the VCM.
Thanks for the info. I’ll look into, need to learn more about the vcm.
