Can I swap my 2002 4cyl ulev vtec motor and tranny with 2000 ex v6 motor and tranny
Old Oct 3, 2020 | 08:24 PM
Cdublu55's Avatar
Default Can I swap my 2002 4cyl ulev vtec motor and tranny with 2000 ex v6 motor and tranny
Can I swap my 2002 4cyl ulev vtec motor and tranny with 2000 ex v6 motor and tranny both automatic. I’ve looked everywhere and can’t find straight forward answer
Old Oct 4, 2020 | 06:37 AM
99stockcivic's Avatar
Default Re: Can I swap my 2002 4cyl ulev vtec motor and tranny with 2000 ex v6 motor and tran
You can swap anything with enough effort.
Make sure to bring everything you can think of over. Not only the engine, the transmission, but the computer, the wiring harness, the intake and exhaust manifold, but also the complete exhaust system s well. I would even grab the motor mounts, exhaust brackets and rubber pieces. While the replacement engine was out, I would also remove and re-gasket whatever you can easily do, such as oil pan, EGR, oil sensors, basically anything that at this age might leak. Then put it in, should work fine.
