Rpm reading
Old Oct 2, 2020 | 12:20 PM
Hidden 1's Avatar
Default Rpm reading
What is the correct rpm reading in idle after warm on a 96 civic non vtech sedan?
Also how important is it to jumper that service connector , in passenger lower dash if your advancing the timing?
Thanks
Old Oct 3, 2020 | 07:00 AM
muellersfan's Avatar
Default Re: Rpm reading
670 rpm M/T
700 rpm A/T
Thanks
Critically important
Old Oct 4, 2020 | 02:26 PM
Hidden 1's Avatar
Thanks.
so if that pin wasnt jumpered vs was what would I notice is different in operation?
Old Oct 5, 2020 | 07:29 AM
Thanks.
You would not be able to set the ignition timing correctly. The engine also must be idling at spec to set the ignition timing correctly.
