So I pulled apart my Z6 to prep it for a vitara setup and when I pulled the crank out of the block I found these small cracks under cylinders 3 & 4, should I trash this block? I don’t want to dump a bunch of money into good parts just to blow a hole In the block, thanks in advance
Those are definitely artifacts from the casting process - nothing to worry about. If you look closely or feel them, they are actually raised above the surrounding surface.
