B16 fuel pump question
Old Sep 28, 2020 | 05:56 PM
Joshjames776's Avatar
Default B16 fuel pump question
My buddy has a 90 hatch that is B16 swapped. I want to help him get it back up and running pretty sure it just has a bad fuel pump so were gonna change it out, he has plans to turbo it though. So the question is can he change to a higher flow fuel pump in prep for the turbo and keep his injectors and everything the same while staying all motor ?
Old Sep 29, 2020 | 12:02 AM
Tuopponen's Avatar
5 Year Member
Default Re: B16 fuel pump question
Yes you can use upgraded fuel pump, but only to certain point. I use 255lph pump with stock injectors and stock FPR at the moment without any problems.
But when you get big enough pump the FPR might be so restrictive that it can't keep the pressure down anymore, so the pressure might rise without control to it.
I personally don't know the limit for stock FPR.
Old Oct 1, 2020 | 06:45 PM
wunfstgsr's Avatar
Loved
Community Favorite
The stock FPR is good for a few hundred HP, I think I heard of people in the 700+ HP range still using a stock FPR, im under 400HP and still use a OEM FPR/ walbro FP.
Old Oct 12, 2020 | 08:23 AM
GIZZ - EXV's Avatar
Loved
Of the Fuel pressure regulators I've tried with a 255 pump and completely stock ecu... The B&M add-on FPR wont regulate pressure down enough, the AEM FRP will somewhat limit a 255LPH. The Holley is the only regulator that I've used that you could completely get pressure down to stock levels.
EddieCRX
Mar 25, 2009 12:22 PM
Ek4 life
Jul 6, 2008 02:43 PM
CoolRedXylophone
Mar 2, 2006 07:46 PM
Todapwr
May 12, 2004 07:52 PM
