Need del-sol ac wiring help
Old Sep 28, 2020 | 12:24 PM
yugisxrc's Avatar
Default Need del-sol ac wiring help
Need some help diagnosing a del-sol ac system. This plug on the passenger shock tower for the ac relay harness shows low voltage on the side of the plug with 3 wires. The voltage shows around 2v on each of the 3 wires individually tested. The other 2 wires the voltage reads fine. What could be causing this? I will gladly compensate whoever can help me figure this out. Thanks
Old Sep 28, 2020 | 10:03 PM
Azliving's Avatar
5 Year Member
Default Re: Need del-sol ac wiring help
That is connector C209.
https://honda-tech.com/forums/honda-...-help-3248368/
The linked thread should have everything you need to troubleshoot.
Hope it helps.
EDIT: Opps wrong link, I'll try and post a better pic from the electrical manual
Old Sep 28, 2020 | 10:27 PM
Azliving's Avatar
5 Year Member
Here is the wiring for C209.
93 del sol AC
93 del sol ac
Hope this helps.
Old Sep 29, 2020 | 12:53 PM
muellersfan's Avatar
Did you check whether hood fuse 35 and/or dash fuse 13 are blown?
Tom B.
Apr 25, 2015 06:12 AM
eskerley
14
May 20, 2008 02:38 PM
dohcFTW
Apr 22, 2008 11:10 AM
jtd87man
Nov 6, 2006 10:04 PM
