F23a1 to F23a
Old Sep 28, 2020 | 08:45 AM
Kyler Yorke's Avatar
Default F23a1 to F23a
So I have a 2001 Honda Accord coupe and I just did a swap from the f23a1 to the F23a. It’s done but my problem is when I give it gas it just wants to quit on me I’m not sure if it’s the distributor or not can someone help me out it the distributor from the f23a1 the same as the F23a I just took the one from the f23a1 when I did the swap and I was wondering if that’s the problem I noticed when I go to look at a new one there adjustable and the one I took from my f23a1 isn’t
Old Sep 28, 2020 | 12:36 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: F23a1 to F23a
Since '96 with the introduction of OBDII USDM distributors are non adjustable. Upper slot is replaced with a hole.
As long as your camshaft is timed correctly to the crank, you don't have to worry about ignition timing.
When replacing the A1 with an A, with the exception of the exhaust manifold, all other components and brackets should be taken from the A1 and installed on the A engine.
Although similar, the A engine has a few minor differences that will not work quite right with the A1.
One of the easily minor mistakes to make is swapping the TPS for the MAP sensor plugs. Verify these are not swapped incorrectly.
Old Sep 28, 2020 | 02:01 PM
would that cause my car to die when I give it gas it idles fine just quits when I give it gas
Old Sep 29, 2020 | 10:05 PM
GhostAccord's Avatar
Yes it would.
Old Oct 2, 2020 | 04:32 AM
Originally Posted by GhostAccord
Yes it would.
it was the tps sensor an map sensor plugs backwards thanks for your help much appreciate !
Dm914
Jul 6, 2019 03:16 PM
Jetro2009
Jan 17, 2010 10:06 AM
Makavelicybe
Jan 9, 2006 05:44 AM
PRoJecTSLeePaLoT
Jul 31, 2005 07:39 AM
mattmw88
Jun 11, 2002 04:26 PM
