how to install a tranny cooler...
Old Nov 16, 2002 | 02:47 AM
iam7head's Avatar
Default how to install a tranny cooler...
http://www.jcwhitney.com/product.jht...364540&BQ=jcw2
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1872504425
thinking of getting one of those for my old beater
anyone know how to install one?
where the "box" things suppose to go in anyways...
thanks
[Modified by iam7head, 11:54 AM 11/16/2002]
Old Nov 16, 2002 | 08:18 AM
gogeeta13's Avatar
Default Re: how to install a tranny cooler... (iam7head)
well, mounting the tranny radiator is usually something of personal preference/where it will fit. In this case maybe someone has already done it, and can give you a recommended mounting location.
Old Nov 16, 2002 | 12:37 PM
iam7head's Avatar
Default Re: how to install a tranny cooler... (gogeeta13)
Thx...
bumps..
Old Nov 16, 2002 | 06:45 PM
iam7head's Avatar
bumps
Old Nov 16, 2002 | 07:55 PM
carolinaACCORD's Avatar
well i've never done it before, but i belive it goes something like this...
First off let the car sit for a while to cool down, because the fluid will be hot.
You need to find the ATF cooler hoses that go from the tranny to the factory radiator.
Next you need to determine a good place to put the aftermarket cooler that will provide good airflow; while staying close enough to the transmission, so you wont have to lengthen the hoses too much (which will drop pressure). If you get a small, compact one, it should do fine in the lower grill area. If you do, and your car is turbo, remember to put it behind the IC. You'll just have to look and see where the best place to put it would be.
Once you have that part taken care of, mount up the cooler, disconnect the hoses from the factory radiator, and connect to the aftermarket unit.
Coolant will come out so have a bucket and towel handy to clean up the mess.
Once finished, check fluid level and fill if needed (which it will).
If you have a Helms, it shows you where the hoses are.
I shouldnt take more than a couple of hours, at most.
If someone has any more to add/correct, please do so.
[Modified by carolinaACCORD, 12:08 AM 11/17/2002]
Old Nov 17, 2002 | 09:13 AM
bmm89's Avatar
Default Re: how to install a tranny cooler... (carolinaACCORD)
carolina is correct...
heres a pic of my coolers, tranny is on right farther down...
[Modified by bmm89, 12:13 PM 11/17/2002]
Old Nov 17, 2002 | 09:44 AM
Default Re: how to install a tranny cooler... (bmm89)
bmm89, what kind of cooler is that?
Old Nov 17, 2002 | 10:21 AM
SOHCArchangel's Avatar
if you are going to install a tranny cooler take the time to install a tranny remote filter kit as well, the type that uses spin-on filters (i never trusted them oil screen pos' inside the tranny)
http://store.summitracing.com/partdetail.asp?part=4479
Old Nov 17, 2002 | 10:58 AM
Default Re: how to install a tranny cooler... (SOHCArchangel)
Im sure they filter a hell of a lot better also.
Old Nov 17, 2002 | 11:05 AM
yeah man, and you can put the oil filter magnet on the filter and trap more metallic particulates, your tranny will thank you ^_^
Old Nov 17, 2002 | 11:55 AM
bmm89's Avatar
its a "cheap" permacool from summit, both of them... i forgot the p/n but the are like $20-30... and they are strapped with zip ties for the most part with one stainless clamp each... just in case...
Old Nov 23, 2002 | 01:09 PM
iam7head's Avatar
thx all
Old Nov 26, 2002 | 10:25 PM
iam7head's Avatar
do you guy think mounting the tranny cooler in front of the radiator is a good idea?
coz i was reading option2(nov) and the japanese dude is mounting the oil cooler(turbo) there too..
Old Nov 27, 2002 | 06:20 AM
KTeller8's Avatar
did you get yours already? sorry i ve been out of it
i think that it would ok to install it there
Old Nov 27, 2002 | 06:27 AM
Default Re: how to install a tranny cooler... (KTeller8)
well, heh, what good would it do installing it behind the radiator? the fluid would not cool
but you can do it on the pass side of the front bumper if you want to, particularly if you have other stuff getting in the way, but you would have to cut vents in the side and possably the front to feed it (or just re-roue air from front or port in front lip if you have one.
i dont like tube and fin (i dont think it dissipates heat enough[lack of surface area]) i use a stacked bar and plate made by setrab for my oil cooler
Old Nov 27, 2002 | 06:36 AM
or you could install a functional roof scoop and duct the air down the a-pillars inside the car, through the floorboard, and onto a cooler mounted underneath the car. of course i would never do that to a daily driven car, and not just because i hate the look of roof scoops.
Old Nov 27, 2002 | 11:53 PM
iam7head's Avatar
LOL i hate those side vents/scope that leads to no where..lol
I am thinking of mounting the cooler on the left bumper vents.
since the right side is full due to my CAI.
no it's not here yet, the shipping is really slow..
thx guy
Old Nov 30, 2002 | 10:49 AM
iam7head's Avatar
Just got the tranny cooler today..talking about slow shipping..
Old Nov 30, 2002 | 12:14 PM
raceACCORDingly's Avatar
slow shipping...
thats why i got my stacked plate tranny cooler from Kragens. after u add up the costs for shipping its about the same but without the wait.
ok now, whats a tranny remote filter kit? is it an inline filter that goes on the tranny oil return hose or something like that?
Old Nov 30, 2002 | 12:21 PM
iam7head's Avatar
Default Re: how to install a tranny cooler... (raceACCORDingly)
i think the filter thing mounted between the oil return line..
I'll get one later..and the magnet poo poo too
Old Nov 30, 2002 | 12:25 PM
iam7head's Avatar
pardon my dumass but i cant tell which one is the tranny oil return line from
the supply line..one is black and one is silver.
cant feel the much about the heat tho' since my header is baking everythign inside of engine bay.Help!!!
Old Nov 30, 2002 | 05:17 PM
iam7head's Avatar
nevermind..problem is solved..
everything should run fine
thx all
Old Nov 30, 2002 | 05:20 PM
Desslok's Avatar
Which was which?, I looked in my manual but couldn't find anything useful.
Old Nov 30, 2002 | 05:33 PM
iam7head's Avatar
Default Re: how to install a tranny cooler... (sp)
http://www.imagestation.com/album/?i...ulation_page=Y
Old Dec 2, 2002 | 04:57 AM
Stew Pidasso's Avatar
Great job The headerwrap looks nice too...
