obd2 link error/misfire
Old Sep 26, 2020 | 07:33 PM
nachahmer's Avatar
Default obd2 link error/misfire
Ok, so I have a 00 civic, completely stock. Took out engine and trans to rebuild seals. Ran tip top before. obd2 read fine. After putting everything back together I now have a misfire mainly at idle, and can’t get obd2 to read codes.
here’s what I’ve done
-checked all fuses. 0 blown
-obd2 has power
-timing is set and checked twice
-spark plugs gapped correctly
-new wires new plugs new cap and button
-distributor is in time
im at a loss. I can’t wrap my head around it.
Old Sep 27, 2020 | 04:52 AM
nachahmer's Avatar
Default Re: obd2 link error/misfire
Bump. Anyone?
Old Sep 27, 2020 | 06:03 AM
muellersfan's Avatar
Can you read CEL codes by jumping the 2P service connector above the ECU?
Old Sep 27, 2020 | 08:43 AM
nachahmer's Avatar
I have done this, I’m getting 1 short flash, pause 6 long flashes, 5 short flashes, repeat. Which if I deciphered correctly comes back to O2 sensors. Unplugged them car runs a little smoother, but still misfire.
earlier in the day I got misfire codes on 1 and 2, took spark plugs out checked gap and put back in reset ECU and they haven’t come back.
Old Sep 27, 2020 | 09:03 AM
The hood fuse for the data link connector may be blown. Locate and test it.
Ohm test the coil.
Is the engine idle set correctly?
Old Sep 27, 2020 | 09:13 AM
nachahmer's Avatar
Ohm test the coil.
I did check the fuse it’s good, also just for giggles looked at every fuse in the vehicle they are all good.
Im on my way to check the ohms now.
How would I know if the engine idle is correct?
Old Sep 27, 2020 | 09:19 AM
Does the installed DLC fuse show battery voltage on both test tabs?
Read the Ohms on your multimeter while touching the two probes together. Subtract the reading from the reading you get on the primary coil winding.
What Civic engine do you have? Use an external tachometer or code reader to read the rpms of the fully warmed up idling engine. Post the rpm reading.
Old Sep 27, 2020 | 09:44 AM
nachahmer's Avatar
Yes tested with a test light on both sides.
Ok, I am on my way to the vehicle I should be there in about 45 min.
d16y7
I will do this also.
Old Sep 28, 2020 | 06:36 AM
Did you verify that your code reader works in a different car? If so, use your multimeter to check whether (1) DLC pin 8 gets battery voltage and (2) DLC pins 12 and 13 have continuity to body ground.
Old Sep 28, 2020 | 06:42 AM
tony_2018's Avatar
Fish Twig
Anything you want to say about the ecu?
Old Sep 28, 2020 | 07:07 AM
Old Sep 28, 2020 | 03:24 PM
nachahmer's Avatar
Ok so update. The misfire was caused by a simple mistake. When I rebuilt the seals I tossed the old air filter and forgot to put in a new one. Caused the air to fuel ratio to go whacky I guess. Not sure what caused o2 sensors to trip, but they seem to be in working order now.
Reset ECU again, drove around 75 miles no CEL no codes. But still no OBD2 functionality. Will be taking the multimeter to it tomorrow afternoon.
Old Sep 28, 2020 | 03:29 PM
nachahmer's Avatar
Yes tried multiple scanners that work in other vehicles. (3 different brands) I will be doing multimeter test tomorrow. Thanks for all the help! Will update with any finds.
Old Sep 29, 2020 | 01:45 PM
nachahmer's Avatar
ok update, I am getting 12 volts on pin 8, continuity is reading 0.00 on both 12 & 13
Old Sep 29, 2020 | 01:51 PM
The next step is to test the data line at pin 15. The wire at pin 15 runs to ECU pin A21. Check the Blu/Yel wire for a lack of continuity and for a short to ground.
Old Sep 29, 2020 | 02:08 PM
nachahmer's Avatar
ok pin 15 reads 0.00 when black wire is ran to it and red wire is ran to a ground. But read 3 volts when the red is touching the pin and ran to a ground.
Old Sep 29, 2020 | 03:16 PM
You may have a short to ground on the Blu/Yel wire.
Unplug ECU connector A and repeat the short to ground test on ECU connector pin A21 with key OFF. Do you still get a continuity to body ground reading on pin A21?
Old Sep 29, 2020 | 04:50 PM
tony_2018's Avatar
Fish Twig
Then I would check the wires behind the DLC, or look directly at the DLC and check to see if there are any burnt marks.
Old Sep 29, 2020 | 04:59 PM
nachahmer's Avatar
A21 reads at 147.2 ohms. Does this indicate a short?
Old Sep 29, 2020 | 05:18 PM
nachahmer's Avatar
update, the reading may be incorrect I’m just getting OL now.
Old Sep 29, 2020 | 05:28 PM
nachahmer's Avatar
nothing visible out of the ordinary
Old Sep 29, 2020 | 05:43 PM
Did you test the Blu/Yel wire for continuity between DLC pin 15 and ECU pin A21?
If the Blu/Yel wire is fine, then the ECU would be the prime suspect.
Old Sep 29, 2020 | 06:05 PM
nachahmer's Avatar
Sorry a bit confused are you saying put one end of the meter on DLC Pin 15 and the other end at A21?
Old Sep 29, 2020 | 06:32 PM
That's one way to do it.
Old Sep 30, 2020 | 10:51 AM
nachahmer's Avatar
ok with multimeter set to ohms key off black wire ran to pin 15 from multimeter red wire ran to a21 from multimeter it reads 30.0 with the ECU plugged in. Read OL with unplugged.
