90 DX hatch failed start after starter change
Old Sep 24, 2020 | 11:59 AM
fakieshulgin's Avatar
Default 90 DX hatch failed start after starter change
Starter in my d15b2 went out so I threw in an obd0 ZC starter, the starter works and everything, verified by my cam gear is spinning but the car combusts for a millisecond when starting then immediately stalls. Only ideas I have is that the disi died while sitting, or that the last time I push started it it to life before the starter change the belt jumped a tooth as it did stall randomly then but I just assumed it was my foot work. Any ideas? Gonna check the disi and timing after work but figured I’d get some insight.
Old Sep 27, 2020 | 06:05 AM
Marcos Barrios's Avatar
Default Re: 90 DX hatch failed start after starter change
could be that the rotor in the dizzy just got a little corroded from sitting
a little sandpaper and grease on the rotor should get that fixed
after thats done just check for spark
see if you have it or not
also make sure that you hear the fuel pump priming when you turn the key to the number 2 position
hatcht9x
Dec 20, 2023 09:38 PM
jdmed3
Jan 7, 2009 07:08 AM
crxaddikt
12
Nov 24, 2008 06:47 PM
TiffanyJJ08
Oct 3, 2005 12:35 PM
