First off, I'll admit most of this stuff could be garbage. I bought my GSR back in 2009 and with it came a bunch of stock hardware before undergoing a transformation to a dedicated autox vehicle.The car is since sold but the new owner didn't want any of this stuff. Just the extra wheels, fenders, and brakes. If anybody has a project and can use anything here, it's free, just pay for shipping. I'm not the most technical, don't even know what some of these parts are. Anything left at the end of 2020 goes in the garage. PM me with what you want, your name, and zipcode and I'll quote the freight cost to be sent via paypal if agreed. Thanks for looking.
Brian
Pic #1 ABS ECU * GONE *
Pic #2 pulley is GONE
Pic #3 Bracket is gone
*GONE* Pic #4 Intake manifold valves
*GONE* Pic 5, some intake cable
Pic 6, motor mounts
Pic 7, fuel pump?
Pic 8, rear wiper motor
Pic 9, most of a steering wheel
*GONE * Pic 10, jack
Pic 11
*GONE * Pic 12, ABS brake harness?
Pic 13, sway bushings/clamps, endlink, *GONE IAM vacuum tank and spare tire hold down *
Pic 14 OEM and ext lug studs, hub rings, bushings only *GONE*
Pic 15, AC Evaporator is GONE
Pic 16 Intake manifold is GONE
Pic 17 Battery trays still here - metal brackets and support are both GONE
*GONE* Pic 18 stereo w/o Sirius satellite
Pic 19, dash insert still here *DOME LIGHT AND CLOCK SPRING BOTH GONE*
Pic 20 sunroof parts are GONE Pic 21 upper front control arm ? + ? Middle black mount is GONE
Pic 22 front wheel hubs are GONE
Pic 23 bolts
Pic 24, no idea
Pic 25, more strange pieces
Pic 26 Air intake tube *GONE*
Reason: better descriptions
John, here's more pics of the AC evap. Was working when pulled, previous owner pulled out all heat and cooling parts for weight savings. Some obvious dents on the backside from handling, front debris would probably blow out with a compressor easy enough.
Just the bushings in pics 13, 14, and 21. Oh, and a pair of 15x6.5 black steel wheels that weren't in this ad. Here's the ebay ad on those, no cost to honda-tech members, just shipping. https://www.ebay.com/itm/303825535568
