Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2003 K24A4 P0497 problem
Old Sep 17, 2020 | 02:47 PM
LSteggyguy's Avatar
Default 2003 K24A4 P0497 problem
I've had this CEL pop on for the 2 years I've owned this car. I've replaced the gas cap and the evap purge solenoid (autozone unit) with no change.
The CEL will pop on every hundred miles or so and I'll clear it, although I have gone a few thousand sometimes in the summer. The light never goes out on its own, always has to be cleared.
It pops on more frequently in cold weather than it does in warmer weather it seems.
I don't have a scanner with the ability to command open certain valves so I'm kind of flying blind.
Any common causes that I might try to replace with the parts cannon and see if it works?
Old Oct 14, 2020 | 08:06 PM
Accordian47's Avatar
10 Year Member
Default Re: 2003 K24A4 P0497 problem
Without the factory scan tool and/or a smoke machine its very difficult to diagnose an EVAP system. As it sounds like you know, techs generally tend to use the Honda scan tool, connect a smoke machine and operate the various valves/components to isolate each area in the system and find a leak.
It could be the fuel tank pressure sensor, the purge solenoid, the canister vent shut valve, the canister itself. The list goes on.
elnoyl
Honda Civic (2006 - 2015)
Aug 29, 2021 07:26 PM
SIRIUS VTEC
Mar 16, 2009 01:48 PM
GaGen6v6
Aug 12, 2005 12:05 PM
Infinity_Racer
Honda S2000
10
Dec 31, 2004 05:06 PM
COREY ITR#625
Jan 15, 2002 10:38 AM
