Need help 2002 Honda Sabre VT 1100
2002 Honda Sable VT1100. My bike is cutting out when i try to run an idle speed. It has a 6Sigma jet kit a main idle on back is 185 and the front main idle is a 180. I have only one metal shim in the slide. And should i have two. Plus the needle jet i have is a touch shorter than the original. But looks the same in diameter. It has a little bit of a rough idle. Not much. Take off is fine. And when it is trying to level out , it wants to act up. If i give it throttle is takes off and wants to do 100mph????
Gurnee Matt
Honda CR-V & Element
Apr 16, 2018 03:07 AM
trans_ponder
Jan 31, 2007 12:55 PM
E-spec Tuner
May 3, 2004 11:16 AM
