Best way to extract trans mount studs when swapping transmission?
Hi There,
I'm in the process of swapping a 1998 Honda Civic B4RA out for a slightly newer BDRA. I want to use the transmission mounting studs from the old transmission on the new transmission. What is the best way to get the studs out of the old transmission -pic attached? Are they left hand threaded into the case? Don't want to damage them. Alternately are they readily available by honda part number? I don't have a a good shop manual for the car yet.
Thx
Ian Studs to extract?
Reason: adding BDRA pic
Re: Best way to extract trans mount studs when swapping transmission?
Take the two nuts, put them on one stud and tighten them together, then use the bottom nut to turn counter-clockwise. The nut above will prevent them from turning around the stud and allow stud to thread out of trans.
