2002 Civic overheating and not shifting
Ok, I am at my wit’s end. I have a 2002 Civic DX automatic. It was running fine and on longer trips started to overheat. Then it started not wanting to shift gears. I tested the TCC and the shift solenoids and all tested fine. I changed the transmission fluid and then checked it and it went into gear and drove for about 5 minutes before it didn’t want to pull anymore. I parked it and it immediately started overheating. I shut everything off and restarted it and it would go in gear and pull and then just as fast it would not pull and started overheating again. Is this a problem with the ecu? Prior to testing I pulled a P0740 and P0730 code. Please help!
The P0740 and P0730 codes are considered the death codes for the auto trans. You may have clutch debris in the trans blocking the internal filter, ports and or solenoids. Did you do drain and fills of Honda OEM DW-1 ATF prior to this issue? Hopefully you did not flush the ATF as it is not recommended by Honda.
Unfortunately you may have both of the 2 biggest problems with these vehicles: breached head gasket and a failed auto transmission. Sorry to be the bearer of bad news - I feel for ya - I had a Honda Odyssey van with a failed trans and my current ride is an Acura EL that had its head gasket replaced due to overheating.
logansuttle
Sep 19, 2017 03:29 AM
PoorDad
20
Oct 2, 2016 02:14 PM
jaypro10
Nov 26, 2015 09:06 AM
JackpotCharlie
Honda Civic (2001 - 2005)
Jan 27, 2015 05:11 PM
