O-Ring Sizes for 1995 Civic EX Coupe ABS Pump/Accumulator
Anyone know if their is an O-ring repair kit or the size(s) of the O-rings on the ABS Accumulator/Pump for a 1995 EX Coupe? It seems as they age they can cause the pump to over pressurize triggering the ABS light to come on. Thanks!
Re: O-Ring Sizes for 1995 Civic EX Coupe ABS Pump/Accumulator
Hey TomCat39,
Thanks for the reply! Sadly Honda does not sell the O-rings for this item. I was hoping someone had an aftermarket repair kit as the replacement parts from Honda are no longer available. Looks as if I will need to remove this, measure, acquire install and hope it will address the problem. Thanks again for your input.
Cheers!
It has been discontinued buy Honda and evidently there is no aftermarket manufacturer. Only option other that rebuilding is to put in a junk yard part. Seeing this car is 100% original mechanically I'm going to go with rebuilding the one that came with it. Thanks for the help.
