1991 civic si running rough and dying
Old Sep 8, 2020 | 05:45 AM
miles visconti's Avatar
Default 1991 civic si running rough and dying
Car was running with an idle surge for a week, left it for a day and it wouldn't start. Wasn't getting fuel past the fuel filter, replaced. Wasn't getting fuel past the injectors, replaced. Cleaned the IAC and replaced the alternator because 300k mile civic.
So now it starts idles rough, runs rich and then pops a check engine light idles up to 3k rpm and dies. The ECU blinks 5 times (manifold pressure?).
I found a line with a broken boot that runs from the firewall into something under the intake manifold not sure what it is.
I really appreciate any advise you guys can gleam from all this I'm new to civics and auto repair in general
Mystery line
Tha is again
Old Sep 8, 2020 | 07:23 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: 1991 civic si running rough and dying
Welcome.
The mystery line is the speedometer cable. It runs from the mechanical VSS (vehicle speed sensor) on the transmission, through the firewall, and into the back of the speedometer.
The check engine light is indicating an issue with the MAP sensor. If I recall correctly, your MAP sensor will be firewall mounted instead of directly mounted on the intake manifold. To see what the manifold pressure is, this remote sensor requires a vacuum line from the intake manifold to the sensor. If this line is broken/cracked/leaking, it can cause an idle surge. If the line completely comes off or the leak is bad enough, it can cause the engine to not run.
I suggest you carefully check all of your vacuum lines on the engine and replace any that may be brittle or are obviously damaged.
Old Sep 8, 2020 | 03:32 PM
Originally Posted by DaX
Welcome.
Thank you so much for responding, it turns out this was half plugged in and when I was fiddling with the vacuum lines it was jiggling the connector around. Now my civic is feeling fine 😎
Old Sep 9, 2020 | 12:40 PM
DaX's Avatar
DaX
Loved
Community Favorite
That is the radiator fan switch. It shouldn't have any influence over how the engine runs.
Old Sep 9, 2020 | 04:27 PM
Hmm, idk then. The car has been no issue since plugging her in. Maybe it was causing a short circuit? It looks like the car's been rewired before.
Old Sep 10, 2020 | 06:16 AM
TacoCat's Avatar
5 Year Member
The coolant temp switch is a ground switch in which provides a path to ground to fire the fan relay (or just grounds the fan if you don't have AC). If you "short" a ground, all you do is complete the circuit and the fan would turn on. There is zero chance this had anything to do with the issue as described.
Old Sep 10, 2020 | 07:36 AM
Thank you for the info I'm always happy to learn, I'll keep my eye out for anything else out of place then
hondamyheart
Apr 3, 2023 05:23 PM
dscarps
Honda CR-V & Element
Apr 2, 2016 10:30 PM
HamiltonRex
Sep 1, 2010 08:40 AM
1_bad_b18_acura
Apr 12, 2009 04:52 PM
B16C-RXed
Jun 12, 2002 05:59 AM
