Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
09 Accord 4 Door Weather Trim
Old Sep 7, 2020 | 09:23 PM
stevesie's Avatar
Default 09 Accord 4 Door Weather Trim
I'm having some water coming in through the soft rubber weather strip at the top of my doors, in part due to a roof rack that I never took off when it was not being used. From talking to the dealership, I believe these are called the Door Weather Trim, but I'm not positive on that (pictures below). Can anyone confirm what these would be called, and/or the part number for them?
Also, it sounded like the dealership wanted to quote about 6.5 hours of work to replace them but I wasn't keen on the price they were asking to do it. Is replacing these something that could be done at home without too many specialized tools, beyond say some sockets or a screwdriver?
Cracked trim from outside of door
Cracked trim from inside of door
Old Sep 7, 2020 | 11:48 PM
stevesie's Avatar
Default Re: 09 Accord 4 Door Weather Trim
From checking the Honda estore, it looks like they may call this the 'weatherstrip', and if so it would be 72350-TA5-A02 for front left, 72310-TA5-A02 front right, 72850-TA5-A02 rear left, 72810-TA5-A02 rear right. Is that the right part for the soft rubber gasket in the pictures?
Old Sep 8, 2020 | 06:58 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Those appear to be the correct part numbers.
On each door, you'll have to remove the mounting bolt for the door checker so you can get the weather stripping out and put in the replacement.
Other than that, the weather stripping is held on with various plastic clips.
Old Sep 8, 2020 | 02:07 PM
stevesie's Avatar
Thanks for the info, I appreciate it.
TougeAccord
Honda Accord 2018- Current
Oct 31, 2019 11:51 PM
Shadowsstrife
Apr 21, 2017 06:51 PM
southeastbeast
Oct 25, 2007 11:19 AM
