Eagle rod bolts needing resizing in a b18c1?
Old Sep 6, 2020 | 02:47 PM
purposebuilt's Avatar
Default Eagle rod bolts needing resizing in a b18c1?
hi i was woundering. Im building a na gsr and using a set of eagle rods with a arp 2000 rod bolt and was woundering if these need to be resized after torqued or do these get resized at the factory. Thanks in advance
Old Sep 6, 2020 | 06:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default re: Eagle rod bolts needing resizing in a b18c1?
What do you mean by "resized" ?
Old Sep 6, 2020 | 08:45 PM
the big end when you torque down the rod bolts incase they distort like a stock rod when you use arp bolts. Sorry if this is a dumb ? Its just ive never used after market rods on a build ive only used stock rods with arp rod bolts and wanna make sure befor putting it together
Old Sep 7, 2020 | 06:22 PM
jdblock's Avatar
It's a good idea to measure any parts going into an engine.
I had my Eagle rods resized, they weren't perfectly round.
What other machine work are you looking at getting done?
Old Sep 7, 2020 | 07:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
In theory, a brand new set of Eagle rods with ARP 2000 bolts should not need to be resized. If by chance, you begin to fit bearings into them and torque them down to the crankshaft and you notice uneven oil clearance or or other indications that they are not properly machined, then you may have to "fix" them.
Old Sep 10, 2020 | 06:30 PM
K20.ek's Avatar
I have ls eagle rods w/ 2000 arp rod bolts in my gsr and measured the clearances with plastigauge and all measure perfectly in the green with acl standards.
Old Sep 10, 2020 | 08:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Did you use a LS crankshaft in the GSR block ?
Old Sep 11, 2020 | 05:44 AM
K20.ek's Avatar
yes sir I did. Have to match the crank with rods 😉
Old Sep 11, 2020 | 09:47 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Just keeping you sharp K20.ek
Old Sep 11, 2020 | 10:32 PM
K20.ek's Avatar
😆 I knew you were testing me. All good though.
RACEPAK
Sep 14, 2010 03:00 PM
EVIL_AWD
Feb 13, 2004 09:31 AM
ARACER25
Oct 19, 2003 09:22 AM
