Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
key stuck in ignition
Old Sep 5, 2020 | 07:52 AM
captainzoop's Avatar
Default key stuck in ignition
Hey guys, my key keeps getting stuck in the ignigion and the only way to get them out is to unplug the battery. I already tried replacing the lock cylinder but that did not fix problem. Any advice would be appreciated!
Here is a video I made of the problem:
Old Sep 5, 2020 | 08:30 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: key stuck in ignition
Next time it happens, check to make sure the shifter button is not slightly depressed; press the shifter button several times to see if the problem still exist.
If the key can come out after pressing the shifter button, then it may due to the plunger (where arrow is pointing) sticking on the shift lever.
Old Sep 7, 2020 | 03:37 PM
Okay, I will try that next time it happens. Thank you for the diagram as well, I was looking for one. Cheers
S33
Nov 17, 2014 11:43 AM
Outlaw-Hondaz
Mar 18, 2011 12:24 PM
*supersonic*
Sep 4, 2010 12:36 PM
exz0n-.-
Oct 23, 2008 04:57 PM
