No core charge, no shipping charges. Ready to go. This is a rebuilt BMXA transmission out of a 01-05 Honda Civic. It has been COMPLETELY disassembled ALL the way down.
DROPPED to $650
- All parts cleaned very thoroughly
- Any sticking valves have been fixed and move easily
- Every single O-Ring, gasket, and seal has been replaced
- Worn steels have been replaced
- Clutches replaced with upgraded Raybestos GPX
- Clutch drum clearances properly adjusted
- Mainshaft and countershaft clearances properly adjusted
- Installed updated larger capacity fluid filter
- Thoroughly cleaned and painted transmission case
- All bearings and races cleaned, checked, and greased
Includes used OEM torque converter, fluid did not have any debris in it when drained.
This is NOT a JDM SLXA that will throw a check engine light. This is a USDM transmission out of a 02 Civic LX, w/ 4.06 final drive. This will work on any 01-05 honda civic with an automatic transmission. I have pictures of every single step of the process that shows that everything has been properly replaced. Thanks for looking!
