AWD Conversion Forum This forum is to help with the recent advent of new AWD conversions. Got a question? Ask it here. Got an answer? Drop the knowledge here
1989 Honda Civic RT4WD. Is it compatible with LSD?
Old Sep 2, 2020 | 05:18 PM
tim russell's Avatar
Icon5 1989 Honda Civic RT4WD. Is it compatible with LSD?
I have a 1989 Honda Civic RT4WD 1.6 Automatic. Is this compatible with my 1991 Honda Civic Wagon RT4WD rear INTRAC Limited Slip Differential?
Also where do I get the replacement bushings for each rear trailing arms, these rubber bushings are about the size of a motor mount.What is the part#? Thanks
Rear trailing arms
Old Sep 3, 2020 | 05:32 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: 1989 Honda Civic RT4WD. Is it compatible with LSD?
I would recommend buying OEM trailing arm bushings. I typically use Majestic Honda to order parts from.
Old Sep 3, 2020 | 06:05 AM
Ryanthegreat1's Avatar
I don't think the INTRAC rear end will fit. The differential housing might swap. The INTRAC was more like a modern dual pump rear end. To use it you would need a shorter driveshaft and to remove the viscous coupler from the middle of the wagon driveshaft.
Old Sep 4, 2020 | 11:34 AM
So for the 1991 Honda Civic Wagon RT4WD rear INTRAC Limited Slip Differential. Which Hondas are the easiest swaps to install on?
Old Sep 4, 2020 | 11:38 AM
Anything is possible. That is just not a popular part being a very rare piece.
Gman2010
Honda Civic (2006 - 2015)
Sep 6, 2020 04:50 PM
jpkillz
May 18, 2017 12:28 PM
rat_barndoor
Feb 27, 2008 01:13 AM
