Tach bounces around, but consistently too high
Old Sep 1, 2020 | 08:44 PM
daedalus921's Avatar
Default Tach bounces around, but consistently too high
My tach is always reading higher than it should, but it bounces around. Also, my radio cuts out intermittently. Bumps will affect the radio as will shifting sometimes. I'm thinking I have a grounding problem and need to replace grounding wires. Can anyone confirm?
Old Sep 3, 2020 | 05:58 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Tach bounces around, but consistently too high
Tach not reading accurately is likely bad capacitors in the tachometer.
Tach bouncing around, especially if it happens the same time the radio is going in and out, is likely due to a ground issue in the dash harness.
I've also had issues with a tach bouncing around where it was the igniter in the distributor going bad. This is where the tach signal originates from.
CLE
12
Oct 31, 2007 07:31 PM
94hondaLS
Jun 23, 2003 10:28 PM
Eg6_JDM
Mar 18, 2002 10:33 AM
