civic 2012 - jump start wrong terminal - changed main fuse
hi Guys,
recently my car was dead and I called a friend to do a jump start, and I did it wrong. (his car had no mentioned which is + and -). So my main fuse was blown (70- 100 AMP). I changed my main fuse however still not power, no lights, nothing.
I called another friend with same honda civic and charge battery for like 10 minutes. and Now I have got my power back, lights and horns are working. However I can see pretty much all the hazard lights. (ABC, battery, etc..) And can't start the car.
what should I check, seems like another fuses have been blown.
If you are lucky it will only be a damaged fused. Worst case scenario is that you might have damaged the ECU since you essentially put 24v into a 12v system. In my limited experience, when ALL of the lights come on your dashboard it means there is an issue with the ECU.
pearl
Honda Fit
Dec 4, 2014 01:33 AM
bboycars
Jun 13, 2006 11:34 AM
utahcoheed
Aug 8, 2005 07:10 PM
