Honda Accord (2013 - 2015) 2013 - 2015 Honda Accord and Inspire
Fuel Cap Leak
Old Aug 31, 2020 | 09:18 AM
edib's Avatar
Icon4 Fuel Cap Leak
Hello everyone,
I just signed up to this Forum.
I have a 2013 Honda Accord Coup V6 with a "CHECK FUEL CAP" warning sign in the dash. I tried two aftermarket caps and reset the codes, after a few days the warning came back on with a check engine light following later.
I finally purchased an OEM cap from the dealership and the same thing happened again. I now have a check engine light again with two codes referring to fuel leak.
What do you think is going on here? Should I double up on the gasket? Is there something else going on?
Thank you
Old Aug 31, 2020 | 09:58 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Fuel Cap Leak
Try this: After every fuel fill-up. just tightened the fuel cap at least 3 clicks. If you tighten it at least 3 clicks, you should not have the issue anymore; unless the gasket was bad.
This info. that is part of published Honda info. to techs/advisers.
RyguyMcFly
Aug 3, 2020 09:23 AM
wa8orr
Honda Fit
Jun 4, 2017 07:51 PM
adrnncbn
Honda Fit
May 5, 2017 02:59 PM
xi007
Jan 26, 2016 04:27 PM
danflanz
Honda Civic (2006 - 2015)
Dec 6, 2013 07:07 AM
