Honda CR-V & Element 2WD & 4WD Element & CR-V
PSA4 transmission vs Z2M4 trans
Old Aug 30, 2020 | 10:38 PM
jfboy's Avatar
Default PSA4 transmission vs Z2M4 trans
Hello guys,
looking at a replacement transmission for a 2003 AWD Manual CRV. The sticker on my original transmission says Z2M4 But the replacement I bought says PSA4.
Does anyone know if there is a difference between the two?
are the gear ratios the same?
Old Aug 31, 2020 | 05:28 AM
Ryanthegreat1's Avatar
Default Re: PSA4 transmission vs Z2M4 trans
PSA4 appears to be a 2006 CR-V. Should still fit and work. HOWEVER, Honda did change some gear ratios between front and rear in the 05+ CR-Vs. Might want to double check they are a match.
I have a 2006 CR-V transmission sitting waiting for a project. I can go check the tag on it tonight.
Old Aug 31, 2020 | 10:30 AM
jfboy's Avatar
Thanks for the info.
For some reason I cannot find any information on the specs of the PSA4 transmission online.
Does it still have a 4.7 final drive?
Old Aug 31, 2020 | 12:12 PM
https://owners.honda.com/vehicles/in...s#mid^RD7786JW
Yes on the 4.7 final drive.
The gearing change may have only been at the rear axle.
Apple395
Honda Civic (2006 - 2015)
Jan 14, 2013 03:19 PM
vyeguy
Honda Civic (2001 - 2005)
Oct 20, 2010 06:09 PM
ThaCivicAssassin
17
Apr 18, 2005 11:49 PM
XzCiViCzX
23
Apr 15, 2004 05:05 PM
LordoftheAccord
Jan 14, 2002 05:08 PM
