94 accord
Old Aug 30, 2020 | 09:32 PM
Andrew Acevedo's Avatar
Default 94 accord
94 accord shifting issues just changed clutch and also the master and slave cylinders car wont shift while on but does when off
Old Aug 31, 2020 | 09:15 AM
99stockcivic's Avatar
Default Re: 94 accord
First check your fluid levels, master and slave probably has air in it still. Can be a pain to get it air-free.
Old Sep 1, 2020 | 05:46 PM
Fluid is good no air in line clutch pedal has pressure. You think i might of put the pressure plate wrong or something
Old Sep 2, 2020 | 07:08 AM
Do you feel pressure when pushing in the clutch? If you feel no pressure, I would think fluid pressue is still the problem, whether a leak or air is what to investigate. If pressure, perhaps you put the fork on in a manner where it's not depressing sufficiently. Can you see the fork pushing as you press? Perhaps you did put something on backwards then. Did you check to make sure everything is facing the right way? Can you adjust the pedal to see if it makes a difference?
Just thinking out loud, I think we've all put in a piece backwards, so please don't take it as any insult.
Old Sep 2, 2020 | 09:18 AM
There pressure on the pedal i did adjust the pedal as well. I wish i could see if its moving its just me and my cd7. Fork moves just fine doesn't seem misplaced. Also gear box fluid is full idk of that has anything to do with it
Old Sep 2, 2020 | 09:28 AM
Always hard when by yourself. I would tie down the pedal and then go look at it to see how it's looking (pressed in sufficently)
Old Sep 2, 2020 | 12:56 PM
Aradin's Avatar
Premium Member
Did you torque the flywheel and pressure plate bolts to spec?
