Need help with wiring 91 civic si
Need help what is the pin out for this plug can’t find anything on it, I trace the wire all the way to a plug underneath the dash it looks like a red plug that is a junction box, The plug is cut off on the actual engine harness and I need to Figure out what connects to in the engine bay it’s a solid yellow wire, is it a power wire
This is connector C212 on the chassis harness side (connects to C153 on engine harness side). Here is what I dug up from my files. I'm not sure of the purpose of the YEL, GRN/BLK, and YEL/GRN wires.
YEL
WHT - Ignitor. Runs to B15/B17 on ECU.
RED/WHT - ECT. Runs to C6 on ECU.
GRN/BLK
YEL/GRN
RED/YEL - IAT. Runs to C5 on ECU.
YEL
GRN/BLK
YEL/GRN
For a 91 Si, that is Connector C217.
Terminal no. - Wire color
1 - Red/Wht : Coolant Temperature Sensor (TW) Input to ECU
2 - Wht : Ignition Output signal from Igniter to ECU
3 - Yel : Under-dash Fuse No. 1 (power to back-up lights switch)
4 - Red/Yel : Intake Air Temperature Sensor Input to ECU
5 - Yel/Grn : Coolant Temp Switch (cooling fan switch)
6 - Grn/Blk : from back-up lights switch to back-up lights
Si-Yaaa!
Jun 20, 2003 10:45 AM
