DA vs EG suspension bushing
Short version, besides the trailing arm bushings are the DA integra and EG civic suspension bushings the same for front and rear?
Long version, I have a an EG civic. And I have some DA trailing arms with the disc brakes I am wanting to put on my civic. And at the same time I am going to upgrade the bushings to harder bushings. I thought I could use the DA integra knuckles and hub on my civic, but the EG trailing arms dont have the bottom bolt hole for one of the brake line brackets. So right now the only trailing arms I have that will work are DA integra arms. So I am looking to see if a DA integra bushing kit will work on an EG with DA rear trailing arms. And I mean the entire suspension as I am going to do the front as well.
I did try searching but all I found were threads about the shock housings being different length.
I think if they are not the same the easiest way would be to get DC trailing arms and get a DC bushing kit because DC and EG are the same except for the trailing arm. But please correct me if I am wrong.
Thanks for the reply. Ok so if I source DC rear trailing arms I can use DC rear trailing arms. DA spindles and hub and brakes. And keep my EG upper, lower, and toes arms. Then get a DC complete bushing kit and it will work?
this is all for rear I know the DC and EG bushings are the same in the front.
Never mind. I got it now. I was getting mixed up and thinking the trailing arm bushings were different from EG to DC. I see that its the lower control arm bushings that are different.
ILUVTEC
Suspension & Brakes
24
Sep 25, 2012 02:11 PM
jdmsir4dr
20
Jul 13, 2010 05:51 PM
rick_rabies
Mar 19, 2010 07:14 AM
Jack Black
May 30, 2005 08:53 PM
