I'm replacing the bearing on the front-right wheel. I've watched a few instructional videos for removing front hubs, but they appear to be for older models. The videos show an upper arm that doesn't seem to exist on my model. Visually, it looks like the hub assembly is attached directly to the strut, and drops from below. (I may not have that correct.) So I was thinking that I need to remove the bolts from the lower arm (circled in red) to allow the lower arm to drop out of the way?
