Oil coming out of Exhaust Manifold.
Old Aug 22, 2020 | 05:18 PM
BobbyFettucine's Avatar
Default Oil coming out of Exhaust Manifold.
I absolutely don’t know where this oil is coming from. I changed the gasket and the head gasket. I don’t see it leaking form anywhere else.
Old Aug 22, 2020 | 07:21 PM
K20.ek's Avatar
Default Re: Oil coming out of Exhaust Manifold.
Could be a bad valve seal or valve guide, are you blowing out bluish smoke out the exhaust?
Old Aug 23, 2020 | 06:34 AM
Just saw this. N the smoke coming out looks more white than blue.
Old Aug 23, 2020 | 07:17 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
More white than blue just means more oil burned than less. Blue is when it's little amounts of oil, when it's larger, it's thicker and more white.
Does it smell sweet? I kind of doubt it does but should ask anyway. I suspect it smells kinda foul.
Old Aug 23, 2020 | 10:44 AM
Smells sweet which I was told that, that’s coolant burning somewhere. Is there anyway to attach videos on here?
Old Aug 23, 2020 | 08:25 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Yes smelling sweet is usually coolant being burned.
How long have you been driving the vehicle? Or is this vehicle recently acquired?
Old Aug 23, 2020 | 08:38 PM
K20.ek's Avatar
Any overheating issues? Could be a bad headgasket or a combination of both oil and coolant leaking into cylinder.
Do a compression test/ leak down test.
Old Aug 24, 2020 | 03:57 AM
chrysler kid's Avatar
Valve stem seals. But if you smell something sweet then it's a head gasket. So do a leak down test, the head could be warped and you are burning oil and coolant
Old Aug 24, 2020 | 08:27 AM
This is a used engine I bought online.
Old Aug 24, 2020 | 08:28 AM
alright. I just replaced the head gasket recently but I’ll check.
yes after being in idle for about 15 min it starts to overheat.
Old Aug 24, 2020 | 08:40 AM
K20.ek's Avatar
sounds like you need redo the headgasket and torque to spec/ sequence. While you have the head off get the shop to have them check the head for worn out valve seals, valve guides and valves. And wouldn’t hurt to have them check for head warp.
if your mechanically incline then you can do the valve seals and valves yourself but have them check the valve guides before putting the head back on to make sure it doesn’t leak oil again.
Old Aug 24, 2020 | 03:21 PM
ill just take it a shop im not to comfortable doing it myself lol. Thank you alot. All the help is much appreciated.
siblues
Feb 12, 2015 05:34 AM
rustyeleio
Dec 26, 2007 11:58 PM
Monkey Fing a Coconut
Apr 18, 2005 05:06 PM
fukaintmuven
Feb 6, 2003 10:39 AM
rustyeleio
Jan 28, 2003 08:39 PM
