CG3 A/C not working, intermittent
Old Aug 21, 2020 | 09:58 AM
typhoon's Avatar
Default CG3 A/C not working, intermittent
I'm noticing my 6th gen coupe AC is intermittently not working. My first guess is... maybe the ambient temp sensor is shorting out, or something like that?
the green lights on the climate control area will sort of flicker, or blink, and usually come back on. It's not just the light bulbs effected, because it corresponds with cold air coming out the vents.
Is this a known issue for any of you?
Old Aug 21, 2020 | 10:40 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: CG3 A/C not working, intermittent
You may have the same problem as indicated in this other thread. See post # 12 relate to the circuit board fix, which links to another post within another linked thread.
https://honda-tech.com/forums/honda-.../#post52235113
Old Aug 21, 2020 | 06:34 PM
typhoon's Avatar
That's quite the rabbit hole, thanks. I see this is definitely a known issue.
lindaloul
Sep 8, 2014 12:15 PM
7808
Dec 21, 2005 12:21 PM
ef93si
Jun 12, 2005 11:23 AM
AndyD
May 2, 2005 09:15 AM
remo
Jan 15, 2005 02:16 PM
