89 honda civic
Old Aug 21, 2020 | 08:34 AM
onebigbyrd's Avatar
Default 89 honda civic
motor idles very high prob around 3000 rpm replace idle air control no help throttle position sensor seems ok car sat for a long time and was started with bad gas, had to pill the head and do a valve job not fun but this car is a gift
Old Aug 21, 2020 | 12:49 PM
jlicrx's Avatar
Default Re: 89 honda civic
check for vacuum leaks, including PVC valve
Old Aug 22, 2020 | 12:27 PM
DaX's Avatar
DaX
Loved
Community Favorite
Post a picture of your throttle body. If it has a dashpot on it, the diaphragm in them it typically torn by now, meaning the spring is holding the throttle plate cracked open, even after then engine is started, and could be the source of your high idle. You can remove this dashpot completely from the throttle body and cap the vacuum line going to it and you should be fine.
Butters54
10
Jan 15, 2018 08:19 AM
xmsdx
10
Apr 15, 2009 01:02 PM
trex352
May 20, 2008 06:15 AM
