Sounds like the car is grounding out or something on startup
Old Aug 20, 2020 | 02:55 AM
USA's Avatar
USA
Default Sounds like the car is grounding out or something on startup
98 Integra ls with gsr swap, well I've got a couple of issues but I'm thinking they're symptoms of this main problem. When you go to start the car the starter will spin and engage but every so often it will cut all power to the vehicle for just a split second then carry on. The other issues are that the idle is rough as hell, it doesn't rev over 3k and it is low on power. The previous owner did move the battery to the back but I really don't see how this could be the issue. I replaced the throttle body, distributor and ECU because I had them lying around and needed a sanity check but I still can't seem to pin down the problem.
USA
Engine Management and Tuning
Aug 23, 2020 03:42 AM
ex_ricer
Apr 29, 2007 06:05 PM
Elemental
Sep 7, 2004 02:08 PM
typerev
Dec 19, 2003 11:47 AM
Titanium White
Aug 18, 2003 06:48 AM
