B16a2- 93 civic cx - won't rev past 3k
Old Aug 18, 2020 | 02:18 PM
jdmtuner012's Avatar
Default B16a2- 93 civic cx - won't rev past 3k
Hey guys, i just swapped a b16a2 into my 93 cx hatchback. I previously had a ls-vtec (gsr head/b18b1) that spun a bearing due to a faulty oil pump, so i got a good deal on a b16a2 and swapped it. The motor cranks as it should, idles great and has great throttle response, but bounces at the 3,000 rpm mark and the needle on the tach moves irradically.
it is throwing 1 CEL for the intake air temp sensor, but thats because I don't have one. I have an aftermarket manifold and there is nowhere to install one (ill figure that out later unless it's the cause of the current issue).
I am going to go over everything and double check connections, vacuum and grounds, but i was just wondering if anyone has seen this and has any suggestions?
TIA
(P.s. I am running a chipped p28)
I4
Dec 2, 2007 05:01 PM
redhbcivic
Apr 6, 2004 05:36 PM
redexchris
18
Oct 24, 2002 05:31 PM
ton
Apr 2, 2002 03:02 AM
