Accord F22B1 with T2T4 or M2B4
Regards,
I have a 1997 Accord with a F22B1 sohc vtec engine, I want to change the box for one with a shorter ratio, such as the T2T4 or the M2B4 that comes in the Preludes.
Will I have a problem when changing? If compatible with the Cuirass? Or would I have to make an adaptation?
Not sure if the VSS sensor connectors are the same or not???? That would be the only thing I can think of to watch out for. Other than that, they drop right in, use the same axles, mounts and all.
