Ac blowing hot air after changing compressor
So i have a civic 92 lx what i put a new compressor and thought that was the problem that didnt work and still blows hot air when ac is on ! I have no leaks . and ac fan turns on what else can the problem be
Is the compressor cycling on and off? If not, does it ever cycle on?
Did you recharge the system yourself after you changed the compressor? Did you pull a vacuum? What was the ambient temperature and what kind of high side pressures were you seeing?
If the compressor was bad, it may have taken out other components. Did you flush the system? Did you replace anything besides the compressor?
A 92 Civic would have had an R12 system - what kind of refrigerant did you recharge with?
lakerschamp2000
19
Apr 24, 2009 12:37 PM
