O2 sensor problems
Old Aug 14, 2020 | 04:09 PM
Redd69's Avatar
Default 98 honda civic O2 sensor problems
So I just replaced my o2 sensors and reset my ecu. I took off driving and noticed the rpm gauge was bouncing and when I hit the gas it pretty much bogged down and acted like it didn't want to run. Can someone please give me some advice as to what to do to try and fix this problem. Thanks
Last edited by Redd69; Aug 14, 2020 at 04:45 PM. Reason: Forgot year make and model of my car
Old Aug 14, 2020 | 04:41 PM
Redd69's Avatar
Default O2 sensor problems
Old Aug 15, 2020 | 06:39 AM
99stockcivic's Avatar
Default Re: O2 sensor problems
What does a scanner show on the sensor readings while driving?
Old Aug 15, 2020 | 07:04 AM
jdblock's Avatar
There is a learning process the ECU needs to go through after resetting it.
Reset ECU and let the car idle until the cooling fans come on twice.
Old Aug 17, 2020 | 11:22 AM
Redd69's Avatar
Ok thanks guys I will try that asap.
Old Aug 18, 2020 | 03:53 PM
muellersfan's Avatar
Have you heard of the fuse 15 TSB?
Is 7.5A dash fuse 15 blown? Are any codes stored in the ECU? If so, what are they?
ken2830
Feb 1, 2008 12:09 AM
AGENT 99
Mar 5, 2006 09:46 AM
crf450ex
Feb 26, 2006 07:15 PM
Hybrid
Jun 3, 2003 01:24 PM
gitwidit
Mar 10, 2003 10:36 AM
