97' Civic (D15B Non Vtec Swap) Idle issue
Hey guys!
Could defs use a hand here. The bottom end of my Y7 was on its way out, so i picked up a D15B and threw it in there with the stock ECU.
I've been successful in getting the car running with no check engine light, however i'm stumped on an Idle issue. It's fluctuating similar to a bad IACV/vacuum leak, but I've replaced the IACV, Map sensor, intake manifold gasket and checked all my lines with no luck. I'm unsure of what else to check and I'm hoping for some ideas.
Any and all help is appreciated!
89efDUSTY
11
May 26, 2011 05:14 AM
salmaan
Sep 24, 2010 08:03 AM
