B16 cam rails / dowel pins
Old Aug 11, 2020 | 01:00 PM
JDM_ego2033's Avatar
5 Year Member
Default B16 cam rails / dowel pins
I have 2 B16 heads one is stamped 88 and the other is stamped 90 and the cam rails are different. The 90's cam rails dowel pins are chewed up and I cant tell if they are supposed to be able to come out and get replaced or if theyre built into the rails. and if theyre built in how should I go about servicing them or changing them? I know mix matching engine parts like this is a no go for the most part
Old Aug 11, 2020 | 08:23 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B16 cam rails / dowel pins
You can remove the dowel pins and replace them.
DelSol-B18
Mar 28, 2014 11:50 AM
Lmgrcivic
Jan 11, 2011 03:51 PM
krazeenoy
Apr 9, 2007 11:37 AM
93slmdcvcsi
Sep 18, 2005 04:59 PM
