How do I know that my audio sytem as amplifiers
Old Aug 9, 2020 | 10:44 AM
dedehonda's Avatar
Default intermittent sound radio on/off issue on fonda accord 2003
Hi,
Recently my radio with one cd for honda accord 2003 as one issue, the sound was turn off and I restart the radio and its turning back on again . I search via youtube where it seems that a lot of trouble with that kind of radio. But I cant find the solution to fix that problem.
Does somebody will help me too fix that please?
Old Aug 9, 2020 | 10:58 AM
dedehonda's Avatar
Default How do I know that my audio sytem as amplifiers
Hello all,
Maybe its a stupid question, but to fix my issue with intermittent sound turning off and turning on back again. I needc to see my amplifiers might be someting to look for fix my issue.
Some posts says the amplifier when theres a power consumption its turn off the radio, I need to know if my radio is wired with amplifier.
Thanks for responding to me
My car Honda Accord 2003
Old Aug 9, 2020 | 11:55 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: How do I know that my audio sytem as amplifiers
For a 2003 Accord, there are different versions of the audio units based on trim level or OEM accessories; however, none of them are configured with an external OEM amplifier. If anything, it probably is an internal problem in the audio unit.
Old Oct 21, 2020 | 03:15 AM
914lps's Avatar
Or a loose or intermediate connection. I would make sure all the connections are good. Not just look good but are good.
Pull the radio, disconnect the plug. Clean the contact on the plug and the radio. Make sure all the wires have a good connection to the plug.
When you loose sound, does the sound just stop, and then comes back, or is the radio actually turning off?
If it is turning itself off does it come back on by itself or only comes on when you turn it on again.
The more detailed the information, the better the answers will be.
If it turns off and on by itself, you have a bad connection either going to the radio or in the radio.
If it is turning on and off by itself and you checked the wires and connectors and even changed out the fuse (fuses can act up), look for a repair shop that can fix the radio for you.
ndzodzo
69
Jun 26, 2019 05:49 AM
leeanne
Nov 4, 2012 07:12 PM
scorr88
Jun 30, 2011 07:07 AM
johnny_honda
Jun 11, 2006 05:24 AM
