2000 Accord v6 odometer and speedometer not working
Old Aug 4, 2020 | 08:57 AM
rdq's Avatar
rdq
Default 2000 Accord v6 odometer and speedometer not working
Can it be fixed by replacing the tachometer? Thanks
Old Aug 4, 2020 | 10:00 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2000 Accord v6 odometer and speedometer not working
Replacing just the tachometer won't fix it.
The odometer and speedometer drive circuits receive pulses from the PCM, which gets it signal from the countershaft speed sensor on the transmission.
Without testing; problem may be with wiring, connectors, countershaft speed sensor, PCM, or gauge assembly.
Old Aug 4, 2020 | 10:09 AM
rdq's Avatar
rdq
Just replaced spark plugs, valve cover gasket and did a transmission fluid drain and refill. Could it be that the mechanic disconnected something by mistake? Thanks
Old Aug 4, 2020 | 10:15 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Did the odometer and speedometer stop working after this was done?
If this happened right after those things were done, check to see if the wiring and connector to the counter shaft speed sensor is okay. But, there should have been no need to even touch that connector or sensor.
Old Aug 4, 2020 | 09:10 PM
Accordian47's Avatar
10 Year Member
Gauge assemblies are usually pretty solid, they don't fail often. Your problem is most likely the "VSS" or Vehicle Speed Sensor (IF MANUAL TRANSMISSION) - OR - the "Transmission Speed Sensor" (IF AUTOMATIC).
They average $50 or so depending and are pretty straightforward to change. You could do a bunch of diagnosing or you could just buy the sensor and try it.
Old Aug 5, 2020 | 06:02 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
6th gen Accord V6 didn't come with manual transmission; so, no VSS on a V6.
CHERRY KELVIN
Mar 12, 2019 06:50 PM
Heinvenkin2
May 2, 2002 02:30 PM
