1995 Accord Crank No Start
Old Aug 2, 2020 | 01:57 PM
Ryannator91's Avatar
Default 1995 Accord Crank No Start
I posted about this car last year but other things came up so I haven’t had any time for it until now. I just started rechecking things like proper fuel pressure and spark which are good. It still runs off of carb cleaner. When cranking the tachometer doesn’t move at all and I am still getting no injector pulse. I have tried a different ecm and a new aftermarket distributor. It has a good battery and connections are good. Thanks
Old Aug 2, 2020 | 03:55 PM
99stockcivic's Avatar
Default Re: 1995 Accord Crank No Start
No injector pulse, but are you getting voltage to the injectors at all? Can you verify they are grounded?
check continuity to the injectors to see if there is a broken wire somewhere.
check the ECU to see if it is even sending out a signal.
Old Aug 3, 2020 | 11:36 AM
I am getting power to each injector and the wiring from the injector resistor to the injectors are all good. What do you mean by check if the injectors are grounded? Like on the body of them? Also how could I see if the ecm is putting out a signal? Thanks
Old Aug 3, 2020 | 11:55 AM
1TSJUSTME's Avatar
Don't the injectors have a constant 12V and the ecm controls the grounding of the injector for the pulse? May be I am wrong but I swear that is how mine works.
Old Aug 3, 2020 | 12:10 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Yes, that is correct.
In addition, the O/P already had a previous separately thread inquiring on no injector pulsing, where I already replied to the O/P that the ECM control how the injectors operate via the ground (-) side. :https://honda-tech.com/forums/honda-...lsing-3342245/
Old Aug 5, 2020 | 09:30 AM
I checked all the wiring from the ecm to the injectors and the wiring from the distributor assembly to the ecm. All good. All the grounds at the ecm are good. I have good power and ground at the distributor assembly. Is it likely that I got a ecm with the same issue as before?
Old Aug 6, 2020 | 04:24 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Here is a video explaining how the ECU sends the ground pulses to the injectors, and testing for the pulses.
Although there are different ways to test if the ECU is sending the ground pulses, if you want to use noid lights, they are usually available at local auto parts stores for around $25 and up; on Amazon, about $18 and up.
The ECU need various power (+) and ground (-) sources to function properly. If the ECU is not sending the ground, you may have to start checking various power and grounds that go in and out of the ECU.
Old Aug 6, 2020 | 05:06 PM
https://www.youtube.com/watch?v=pzeOz-seIQE
Ok thanks. I have used my noid light on all the injector plugs and it doesn’t light. I will verify all the power and ground sources at the ecu.
Old Aug 7, 2020 | 10:17 AM
I verified all the power and ground inputs at the ecm according to this chart. https://rusefi.com/wiki/index.php?ti...da_Accord_1995
On pin A21 power output to the icm I am only getting 6.4v and it shows it should be 12v. It does the same with my other ecm as well.
Old Aug 7, 2020 | 11:34 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Your problems and conditions sounds practically the same as this guy's Civic. The Civic's ECU pin number A20, Yel/Grn wire is similar to your Accord's ECU pin number A21 which goes to the ICM. The ICM is in the distributor and you did mention you had no tach movement, the tach signal comes from the blue wire from the ICM. His fix may have been due to the distributor connection or something.
https://honda-tech.com/forums/honda-...oblem-3337810/
Old Aug 8, 2020 | 10:34 AM
I ordered a main relay just to try since it seems they go bad all the time. My main relay looked ok and no solder joints looked cracked. I put the new one in and now I have injector pulse and the car runs. I know I checked the main relay and I was getting power to the ecm. Maybe it had a slightly high resistance internally idk. Thank you for all the help
Old Aug 8, 2020 | 11:06 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Good to hear you resolved the problem and thanks for reporting the resolution, many times we never know what was the final outcome in threads.
syber
Sep 13, 2014 10:30 PM
zrs6v4
Jun 16, 2009 11:35 AM
phustvedt
Feb 25, 2006 04:12 PM
sk1330
Nov 4, 2005 05:23 AM
