H22 Broken rocker arms 7 of 8 sets. Help.
Old Aug 1, 2020 | 05:46 AM
so_vayne's Avatar
Default H22 Broken rocker arms 7 of 8 sets. Help.
I have broken the roll pins on all but 1 set of rockers. Has anyone else seen this? What would cause it and would it make vtec not engage correctly?
Old Aug 2, 2020 | 05:37 AM
so_vayne's Avatar
Default Re: H22 Broken rocker arms 7 of 8 sets. Help.
Anyone ever seen this?
Old Aug 2, 2020 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The one pictured is not broken. I am not sure what would actually cause this kind of damage in a running engine, but it will NOT cause VTEC to fail to function. If VTEC is not engaging in your engine, you have other issues. Your rocker arm pads look unusually worn... what spring/retainer package are you running ? Also, what camshafts and valves ? Has any work been done to the head ?
Old Aug 20, 2020 | 05:20 AM
so_vayne's Avatar
The one you see is a spare. The ones in the engine are all broken. All 16 pins. Vtec works, part time. It feels like it struggles to get there.
The engine is 10 races old. Oil pump is also. Pressure at startup is 80 hot is 25. At idle. As soon as you touch the pedal back up to 80. Solenoid screen is clean. Pressure under vtec is over 60psi.
Old Aug 22, 2020 | 02:31 AM
so_vayne's Avatar
https://honda-tech.com/forums/all-mo...nside-2848418/
Found my answer. LMA too short.
Old Aug 23, 2020 | 05:31 PM
night's Avatar
So you then bumped a 10yo thread..
Old Aug 24, 2020 | 07:07 AM
so_vayne's Avatar
You're correct. And still contributed more to the forums than your previous post.
window44
Mar 14, 2005 08:57 PM
H22A_HB
Aug 23, 2004 04:05 PM
