89 CRX Dash cluster
Old Jul 31, 2020 | 08:24 PM
David Britt's Avatar
Default 89 CRX Dash cluster
Greetings all. My son recently picked out an 89 CRX for his first car. The dash cluster partially works. The speedometer and fuel gauge is not working. Anyone have an idea on where to get a replacement? Aftermarket or original would be fine. Thanks for the help!!
Old Aug 1, 2020 | 12:47 PM
smithenhiven's Avatar
11:11
Default Re: 89 CRX Dash cluster
You'll likely want to get a whole replacement gauge cluster (check ebay). However, gauge clusters rarely go bad in these cars, you may have other underlying electrical issues causing those gauges not to work.
Old Aug 3, 2020 | 06:24 PM
DaX's Avatar
DaX
Loved
Community Favorite
If the speedometer isn't working, it's likely got a broken speedometer cable, as the speedometer is mechanically driven in these cars.
I would inspect the fuel sending unit to make sure it's functioning properly before suspecting the cluster as being the problem.
Do you have a copy of the factory service manual (FSM)? If not, you should be able to find a downloadable copy by googling around. It will have wiring diagrams and troubleshooting flow charts to follow.
BSeriesRescueteam
May 7, 2009 10:29 AM
tyler100
May 27, 2008 10:33 AM
dem0nk1d
Jul 26, 2007 12:44 PM
stevescivic
Feb 27, 2005 09:55 AM
