Bench Testing The ERG Valve?
Old Jul 31, 2020 | 06:58 PM
ducked's Avatar
Default Bench Testing The ERG Valve?
1997 4-cylinder VTEC (Taiwan)
Just done a shift down't Honda Accord ERG pit. Had a shower and need another one. Should have used gloves, and perhaps a Davy Lamp.
The original plan was to take the intake plenum off and wash it, but one of the coolant hoses is hard to get to and after some damage to other hoses I decided to leave it attached.
https://www.driveaccord.net/attachme...02-jpg.522994/
https://www.driveaccord.net/attachme...03-jpg.522995/
I used old brake fluid for cleaning in a syrige sold here for use with cosmetics which has a wider than normal needle without a point, (though of course it clogged eventually) along with a twisted length of doubled stainless steel wire with a double hook at one end and a loop on the other. This worked quite well. Eventually the whole length shown below disappered into the port in the direction of the exhaust and the brake fluid drained away so I'd guess it cleared the blockage.
https://www.driveaccord.net/cdn-cgi/...06-jpg.522999/
Now have the valve off and would like to "bench test" it. I'm EXTREMELY reluctant to do any circuit testing on the car, which is the first computerised car I've had and which I don't have documentation for, but the valve should have less disaster potential.
I believe the three top pins are control (5V) and the bottom two are 12V for the solenoid, but I don't know the polarity of the latter. Any tips for bench testing this gizmo?
No sign of soot on the valve, just light rust on the pintle and port, perhaps suggesting this valve was swapped in after the ERG galleries were completely blocked with coal, rather pointless if true.
https://www.driveaccord.net/attachme...04-jpg.522993/
It says it was assembed in Canada, so, assuming it isn't fake, there shouldn't be much scope for random Taiwanese specification variations.
Last edited by ducked; Aug 2, 2020 at 03:54 PM. Reason: correction of "exhaust plenum"
Old Aug 1, 2020 | 02:19 AM
ducked's Avatar
Default Re: Bench Testing The ERG Valve?
RE "Eventually the whole length shown below disappered into the port in the direction of the exhaust and the brake fluid drained away so I'd guess it cleared the blockage." above, anyone know where exactly that goes?
Can only find generalised "How an EGR system works" stylee diagrams.
If its into the actual exhaust, that should be OK, but if the fluid could drain into a cylinder, hydrolock might be a possibility (Oo-er) and I'd better take the plugs out. There was about 20 mls of fluid.
Old Aug 2, 2020 | 04:11 AM
ducked's Avatar
Looks a bit close. so to avoid the (probably unlikely but dangerous) hydrolock possibility I turned it over with the plugs out.Plug out turnover is essentially the same as for a compression test without the compression tester.
This guy
Pulls a couple of 15 amp fuzes to disable FI and Ign on his 1998 4 cyl VTEC, box drivers side footwell, RHS top and bottom.
COULD NOT find fuse diagram in 98-2002 FSM, nor that fuse box on this car
ETCG, on what looks like an earlier Accord but is a generic how-to video, disconnects the distributor and floors the accelerator, to put it in "clear-flood mode", so I did that.
Plugs look pretty good (though I'm used to old carbed vehicles). Certainly don't reflect the Land of Mordor vibe of the intake path.
Maybe the bit of staining on the porcelain margin is a contra-indication though.
On turnover (3X5 second bursts) there was a noticable smell of petrol, so it seems Eric's Clear Flood Mode ain't always so.
I would have predicted Honda would have engineered the system so cleaning it wouldn't dump muck in the cylinders, and I would have been wrong. Glad I took the precaution. Almost didn't
Dunno whether #4 cylinder is closest to the ERG port, or it just happened to have an open (or leaky?) exhaust valve.
Of course I used brake fluid, which is a very effective cleaner but non volatile, whereas carb cleaner etc would probably evaporate quite quickly even from inside a cylinder.
I found some stuff on the valve pins so I'll test that later. Time to burn some brake fluid.
Oo-er!
Probably not promoting catalyst happiness.
(I've never had a catalyst before. They seem to be a bloody nuisance)
Settled down after a bit of a drive. Seemed to drive slightly worse but still OK. If its no good I'll blank it off and be back where I started.
Old Aug 2, 2020 | 03:40 PM
ducked's Avatar
Didn't think this through.
While turning it over with the plugs out diagnosed fluid in cylinder 4, it did not adequately clear it.
This could perhaps have been achieved by (a) bringing the piston to TDC manually and swabbing/syringing, and/or (b) putting a shorter section of bubble-tea straw in the plug hole and packing the plug tube losely with paper towel.
This would have been harder than with the more accessible engine design I'm used to, but necessary.
As it was there was a bit of a thump on startup, which I can only hope did not cause serious damage
Old Aug 8, 2020 | 04:26 AM
ducked's Avatar
Partly answering my own original question
EGR valve has a 5-pin connector, 3 on the top,(1, 2,3) 2 on the bottom, with a gap in the middle (4,x, 6)
Seems resistance 1 to 2 and 1 to 3 should be < 100Kohms (dunno what the actual readings should be though)
1 to 2 is 1654 ohms, 1 to 3 is 4300 ohms, so in range, if I''m reading it right.
4+6 power the pintle solenoid 4 bat +, 6 bat -
Jumpering these to battery gives a solenoid clicky sort of noise.
Doing it with an idling engine makes the engine stumble, implying my perilous partial clean of the EGR path is sufficient to mainline muck into the engine as designed, though it would have been better to have tried this before cleaning as well, to have a comparision.
Further testing would probably require looking at the computer side, and I'm not doing that.
After leaving the battery disconnected overnight (to clear the CEL) anjd doing the above EGR valve testing I STILL have a CEL code 80 (EGR insufficient flow). so either the clean didnt fix it or a minute or two at idle with a disconnected EGR is sufficient to reset the code.
Is it?
I've disconnected the battery and will see if I still have the code tommorrow.
Old Aug 9, 2020 | 03:08 AM
ducked's Avatar
Still got it. Something other than path clogging seems to be wrong
redcoats1976
Dec 3, 2016 07:54 AM
afnan
Dec 19, 2013 07:13 AM
afnan
Dec 15, 2013 11:07 PM
BI8B
Sep 16, 2003 08:21 PM
