compression test procedure
Old Jul 30, 2020 | 03:43 PM
pull's Avatar
Default compression test procedure
old dude I' Looked at sticky I' saw nothing on doing a basic compression test.procedure.
1991 Honda Civic sedan 1.5 I4
how to disable ignition ?
how to disable fuel ?
the compression numbers 150-184 PSI ? what are good numbers ?
not sure if numbers are at or below 125 PSI need motor ?
following is fundamental
throttle wide open TWO
warmed up
88 civic
Apr 5, 2009 03:21 PM
self_made
Jun 19, 2005 12:36 PM
quaker
Jan 5, 2005 05:33 AM
