98 Accord EX misfires, but runs fine when restarted
Old Jul 29, 2020 | 11:11 AM
ToasterCat's Avatar
Default 98 Accord EX misfires, but runs fine when restarted
As the title says, my 1998 Accord misfires and stalls about half the time I start it in the morning, but runs great if I let the engine idle for about a minute and then restart it. If I let it run without restarting it, it'll keep misfiring. I've replaced the plugs, plug wires, cap, rotor, and ignition coil. What else is there to check?
Old Jul 29, 2020 | 11:35 AM
99stockcivic's Avatar
Default Re: 98 Accord EX misfires, but runs fine when restarted
Do you get an actual error in the computer registering the misfires?
Have you double checked the gap on the plugs? I hvae often found overgapped plugs.
Old Jul 29, 2020 | 11:43 AM
Can you pull each wire to determine which cylinder is misfiring?
You could also check the fuel injector harness to make sure each one is locked in there, but I don't really think that's the issue.
Maybe a valve adjustment? Can you check that youreself?
rwkgramps11
Mar 19, 2023 12:44 PM
Erick Shin
Nov 9, 2015 11:13 AM
Korben
Feb 18, 2011 05:06 PM
honda Racer6
Aug 3, 2009 03:08 AM
monkey229
Feb 21, 2003 04:46 PM
